Application of Loads on FEM model to compare with CLT hand calcs
martin555
Aerospace
Nov 30, 2018
17
I am looking to compare my hand calculations from my classical laminate theory tool to a FEM model.
I am using FEMAP and want to apply a Nx load of 100lb.in.
How does this convert into the FEMAP load definition.
If I use point load the unit would be lbf correct ?
 https://files.engineering.com/getfile.aspx?folder=adb92bdb-a2ee-4f0a-b381-168d517ae528&file=Picture1.png
Nx should be lb/in. (force/width)
You apply Nx along the edge of a shell model plate.
