NX stop working when we loose internet.
hnam2003
Automotive
Mar 29, 2014
23
We have our license install in our 2012 window server. Why do we have problem with NX license when we loose the connection to internet?
Is there something wrong on our side when install the NX license?
How are your NX users connecting to the license server? If they are working remotely and connecting via VPN, then losing the internet connection will be a problem.
www.nxjournaling.com
NX will do a "Handshake" with the license server in "some regular intervals". The handshakes are called heartbeats.
The time between these heartbeats is not published to make hacking more difficult.
I.e NX : "ok continue using license x ?"
License server : "yes."
If these heartbeats aren't responded, NX will stop working after a few lost heartbeats. ( maybe 5-10 minutes)
if the network traffic is lost but later reconnected, NX will/should reconnect to the license without issues.
Tomas
The more you know about a subject, the more you know how little you know about that subject.
