NX 11 Sequence - Motion Not Showing
Gaia_BH1
Aerospace
I have encountered an issue with an NX 11 sequence that has been working flawlessly until today. When I play the sequence, it no longer shows any motion for the parts. Instead, it only changes the camera position and disassembles the components without any movement. The parts are supposed to move before being disassembled, but they remain stationary.
I have ensured that assembly constraints are turned off for the sequence, and I haven't made significant changes since the last time I played the sequence. However, I am unable to identify the cause of this problem.
I can add new motion and it works as expected, but all of my existing motion does not show. I also exported from Teamcenter to try in a native session, but the issues persisted.
Has anyone experienced a similar issue or have any insights into what might be causing this behavior? I would greatly appreciate any suggestions or solutions to fix this problem and restore the part motion in my sequence.
Thank you in advance for your assistance!
