Questions about ABAQUS .inp file 1
joezzc
Student
Sep 6, 2024
1
Dear Abaqus users,
I am a new ABAQUS user and trying to run a simple simulation. However I meet some problems. Hopefully you could take a look and give me some suggestions.
I build an input.inp file (attached to this message) with my CODE where a cube with four C3D8R elements is defined, and pressure is applied to one of its faces whose normal vector is parallel to x-axis, as shown in the attached file. But I get so many errors when I run the job(the input.dat is also attached). To solve the error, I build the same model using ABAQUS user interface and generate a cube_abaqus.inp file (attached to this message too). Comparing two .inp files, I don't really find many difference.
Especially,
1. The first error says my '*ELASTIC' definition is problematic, however this part is the same in two .inp files
2. Why there are more than one Face ID for the loaded surface in '*Surface' section in cube_abaqus.inp? To my knowledge, only the Face ID S2 represents the surface whose normal vector is parallel to x-axis, so there should not be more than one Face ID and the Face ID should be S2. However this is not the case.
Please correct me , thanks in advance.
Sincerely,
Joe
 https://files.engineering.com/getfile.aspx?folder=c8b8fe0d-10d5-4691-a132-1ad7692db916&file=files.zip
Abaqus doesn't like the empty lines between keywords. Remove them and all datacheck errors will disappear.
