Export points coordinate from NX to txt
Saving the information listing to file then parsing that file seems a bit awkward. It would be easier to query each point's coordinates and write them out to a text file (csv) directly. The point object has a .Coordinates property that you can use to get the X, Y, Z values.
www.nxjournaling.com
There's a GRIP program floating around somewhere that does that, it's just that I no longer have access to any of those files, but someone might, so if you do, check it out.
John R. Baker, P.E. (ret)
Irvine, CA
Siemens PLM:
Thanks you so much for the comments, my NX Open is not strong, I will try rewrite it later.
