Allowable stress for flexible pipe.
AnisaMaski
Chemical
MY
Is there any standard/ guideline to determine the allowable stress for flexible pipeline for subsea?
Is it logical to determine the allowable stress based on assumption of 100% SMYS, SMYS = Specified minimum yield stress
Thank you. Appreciated everyone thought on this.
What type of flexible pipe are you referring to? Bonded or unbonded? If unbonded then check out API 17J.
There are many standards and guidelines,depending on your definition of flexible.
No code or standard I know of uses 100% of SMYS to be the allowable stress. 90% for combined stress is as far as it goes.
Flexible pipe does not have an SMYS in the same way steel pipe does, sk you seem to be mixing different things?
