Floor Truss/Beam to ICF Wall
reverbz
61
Hey Guys,
I'm working on an ICF structure with wood floor/roof framing. I've been trying to find details for the framing to the wall at the floor level but haven't had much luck. Do you guys know a resource that has some of these details? Or do you have details you've used before? For the trusses I was just thinking staggered anchors through a ledger and blockouts in the form section of the wall to the middle where we have a "bond beam" with horizontal reinforcing. Does that sound correct?
Thank you!
I've often used a brick ledge block with a sill plate.
