Rampower
- Dec 10, 2002
- 12
How does one compute the annular flow rate given the area? Assume 35 psi and water (@ room temp) as the fluid.
Example: I have a piston within a cyclinder. The annular area between the piston and the cylinder is .091 in^2. Pressure is 35 psi. For ease of calculation consider this a static problem (piston does not move...initially).
