Process to die cast AL7075
SCLing
Industrial
May 14, 2003
1
Like to know what is the best process to die cast AL 7075? Any known supplier in China
There is no process for die casting aluminum alloy 7075. This is a wrought alloy, and it is barely castable into ingots/billets by the direct chill process, much less into complex shapes by the pressure die casting process. The high mechanical properties are developed by controlled deformation and heat treating processes, and therefore would not be possible in any casting process. Feel free to post again if you need assistance with an application.
