screw/bolts into tapped holes
WITT55
I was wondering if anyone has any information/codes on using tapped bolts for structural/ building applications. I have talked with AISC and they are really no help. I have a european client and they use this type of fastener all of the time. I know that it is used in many other industries in the U.S. also but I can't seem to find any info. Also if you have data/references for the tapped screw/bolt allowable loads.
Thank You
When you are bolting into a tapped hole the fastener is defined as a cap screw rather than a bolt. Cap screws have slightly tighter controls and a few variations from typical bolts. This is probably why AISC doesn't get into it. I am not aware of any specifications written for tapping structural bolts. The closest thing I know of is the "Naval Ships Technical Manual Chapter 075- Fasteners" It is available on the web at Section 7.6 covers fasteners in tapped holes and has some tables of minimum depth of tapped holes. All the other documentation I have seen simply states that the depth of the tapped hole should be sufficient to develop the full strength of the fastener.
Good Luck
RockEngineer
Thanks for the link. Most engineers probably don't realize the amount of excellent reference manuals available from the Navy and the Corps of Engineers.
