rawlings
- Jun 19, 2003
- 1
I’m looking for an IC to build a 60 Hz (+/- 1%) frequency simulator. Output should be a 12 to 20 VPP sine wave. I would prefer to use a 12 VDC power source, but that is not likely given the amplitude of the output. A 24 VDC power supply would be the second choice. I know that I could use a 555 timer, but they require external components and I want to keep the device as small as possible. Has anyone seen a dedicated chip for simulating 50 or 60 Hz? Any other ideas?
