tapping size for 1/8" NPT
andy4d
Aerospace
Jun 23, 2003
1
as the subject says, does anybody know the tapping drill size for a 1/8" NPT tap (im fitting an oil temp sender incase your wondering)?
Cheers Andy
Andy,
Make sure you don't run the tap all the way through. A Pipe thread has a taper to it so that it naturally tightens up as you drive the male threads into the hole. I'v seen leaks when this was done.
-elf
11/32" for softer material ie. aluminium, or for harder material 23/64", my experience!
