shei
- May 1, 2003
- 10
The original span of the truss was 17.45meters. During construction stage there was revision on the roof framing which required the truss span to be 23m. Before the revision was final we had the trusses fabricated already. To avoid having the fabricated truss go to waste we tried to redesign the existing truss to meet the required sections of the 23m span.
Here are the methods used:
1) addition of flat bar for the top and bottom chord
2) addition of 2 angles for the web members which make the web members to 4 angles.
Questions:
a) should the 4 angles in the web member be placed back to back? why?
b)the web member of the fabricated truss is placed back to back. If the additional 2 angles be placed such that it will form a box on each side (thus having larger Ix than back to back), is this advisable? Why?
c) what other methods can be done beside those i mentioned in 1 & 2?
thanks and best regards.
Questions:
