Stepper & BLDC simulation
  • Thread starter Thread starter -
  • Start date Start date
Guest
Hi!
1-How to calculate the pull-out torque curve of a stepper motor starting from the resistance,inductance,holding torque,bus voltage in chopper and voltage drive mode?
2-How to simulate a BLDC motor starting from the line to line parameters (bemf [Vrms/krpm],inductance,resistance),
poles number,star or delta connection,to use for evaluate short moves?
Thanks.
We require 3 ph Brushless DC motor of 20,000 rpm,20w,around 35mm size,with sensors.
Please send the availability details as early as possible.
Please send the reply to prabhal@dalmiacement.com
