Taffhughes
- Mar 18, 2003
- 1
Looking for a AC-DC power supply with Triple-Output having the characteristics listed below:
> INPUT: 85-264 VAC, 0.3 A MAX, 50 Hz
> OUTPUT 1: 5 VDC, 0-1.2 A floating
> OUTPUT 2: +15 VDC, 0.2 A
> OUTPUT 3: -15 VDC, 0.2 A
> LINE REGULATION: 0.5 % MAX.
> LOAD REGULATION: 0.5 % MAX.
> SIZE: 110mm(L) x 51mm(W) x 23mm(H) MAXIMUM OVERALL; CHASSIS-MOUNTING, WITH SCREW TERMINALS
I have obviously tried the obvious sources, e.g. Farnell, RS, etc etc and numerous manufacturers found on the net.
Any possible sources?
Tony
Tony
