Turbomad
Automotive
- Aug 27, 2003
- 2
Hello everbody.
I'm currently building a toyota 20v turbo motor for a little tube frame sports sedan racer toyo starlet i have..
Motor specs are briefly, 7.5/1 comp, ceramic coated pistons, 20v head with extensive port work, stock spec cams, ex manifold is equal length feeding into a Garret T3-t4 series hybrid that I recently built.
I'm a little worried about compressor surge..
Turbo specs are To4b comp cover .6ar, 55mm 8blade comp wheel, plain bearing core, stock t3 stage 1 turbine shaft with 0.63ar exh housing, 32mm external 'wastegate'.
Motor does not need any low end but must have good top end as the g/box i have has reasonably close ratios.
Ie: don't need any positive manifold untill 4500-5000rpm.
Looking to run between 2 and 2.4 pressure ratio.
Anyone had any experience with this combination or something similar? Engine is fitted to 600kg vehicle. with 4.8 or 5.2/1 diff ratio.
Can anyone help out with inlet runner length, it will still be running the factory multi throttles with an undecided plenum volume.
Hoping to make over 400hp to make this combination work in my weight bracket, gotta beat the big cube brodies.
Sorry bout the long post but there are so many variables to consider....
