strokersix
- Dec 7, 2002
- 344
I received some good general information regarding material internal damping chracteristics in the vibrations forum. I'm after some more specific information related to the actual application so I'm posing the question here as well.
In 1963 and 1964 General Motors inline six 292 inch displacement seven main bearing crankshafts had six counterweights and were forged steel. Later '60s vintage crankshafts were also six weight but nodular iron. Starting around 1968 until the present the crankshafts have 12 weights and are nodular iron. I'm told the nodular crankshafts are more durable than the steel ones and I have a difficult time believing it. So, my question is two-fold: First, assuming an equivalent geometry, is it possible for a nodular iron crankshaft to be more durable than a forged steel one? And second, what are the structural, torsional harmonic, and durability differences between a six counterweight and a 12 counterweight crankshaft design? All factory applications I'm aware of use an elastomeric damper of typical construction.
If anyone has specific knowledge of the engine in question that would certainly be welcome as well.
