Jon421
Automotive
- Dec 16, 2003
- 6
Ive been working with a formula that is supposed to calculate a compressors discharge temperature when given the inlet temp, pressure ratio and volumetric efficiency of the compressor. I found that when the inlet temperature is lowered that the discharge temp is effected by about 120%-130% of the change in the inlet temp, depending on the volumetric efficiency of the compressor.
For example, with a 1.80 pressure ratio and 70% V/E, when the inlet temp is dropped by 40 deg the discharge temp is lowered by 49.583 deg, a change of 123.956%
Has anyone else ever come across this before? Whats causing the drastic change in the discharge temp? Is this an accurate calculation or is there a flaw in the formula?
I found the formula here, its about half way down the page under "How hot is the air coming out of the compressor"
