Threaded pipe cap on a pressure vessel.
spike
46
Is it possible to purchase a carbon steel threaded pipe cap that meets ASME section VIII? If so, can you name a few manufacturers?
Pipe caps are not designed, per se, by the ASME VIII rules. ASME VIII, UG-11 allows for standard pressure parts that are pressure-rated and meet the requirements of one of several standards. A quick Google search yielded a number of websites that indicate ANSI B16.3 is the standard for forged steel pipe caps. I'm sure that if you check further you will find a website with the pressure rating information too. Hope this helps.
Steve Braune
Tank Industry Consultants
