execute keyboard command from VB 1
jramrus
Computer
Jan 18, 2004
1
I would like to execute a keyboard command such as a 'tab' or a 'return' or be able to enter a character into a textbox on the screen. This would be for Windows XP or like OS.
Jordan
This is done by the SendKeys method.
Cheers,
Joerd
To execute tab you write
Sendkeys ("{TAB}"),true
To execute return,
Sendkeys ("~"),true
Joerd,
In order to use SendKeys, do you not need a file called KEYPUSH.DLL?
Bradley
Dunno, but it's not on my system (W2k)
Cheers,
Joerd
I don't think you need that DLL. SendKeys is an intrinsic command to VB.
In conjunction with the AppActivate command, you can also use SendKeys to send keystrokes to other applications as well.
