kyong
- Aug 15, 2001
- 73
In Section VIII Div 2 Part UCL, the Code reads rules in UCL shall apply to vessel which has over lay weld.
If the tubesheet of a heat exchanger is going to be over lay welded to enhance seal weld reliability of tube to tubesheet joint, is the Part UCL still governing?
