PUMPMANPLEE
Greetings all Materials/Corrosion Engineers,
Does a copper/brass water tank require Anode
corrosion protection for long life service ???
I'm currently constructing a large number of
copper/brass tank which has the following specification:
-A life of 20 years minimum.
-Number of tanks = 25 to 30
-Capacity each tank = 315 Liters
-Used for storing MUNICIPAL potable drinking water.
-The tank will be heated to 60 degrees Celsius
using an electrical element located at the
base of the tank.
-The tank will not be under pressure.
-The tank will have a sealed lid.
-The stored water will flow by gravity to
distribution points downstream.
...thanks for any assistance.
PUMPMANPLEE
base of the tank.
PUMPMANPLEE
