bawest
- May 23, 2001
- 16
Is there a method to set up bolts and screws to default to a plane and axis when inserting. I>E> If I have a part that I need to put a bolt through, I would like to be able to click on the surface and the axis then the bolt automatically be inserted and constrained. I heard this is available in autocad, so I was thinking Catia should allow it also.
thanks.
thanks.
