Tug-O-War
tugowar
CA
I am newbee to designing machines.I am working on a design project. We are trying to simulate a tug-o-war where a team competes against a machine.
I am not getting any idea how to simulate the back and forth motion while the game is in progress.
thanks
Use springs with shock absorbers.
Sounds like fun!
use a long air cylinder and precharge it. it will act as a spring and if you put flow controls in both ports you can control the bounce.
How about a rope and pulley system lifting a weight? You could get creative with the geometry to provide a variable force/displacement effect.
You could try rubber rope, commonly called bungie cord. It comes in different strengths.
