Matterson Gear generating Attachment use
sacem1
186
I hope someone out there has in use or is experienced with the following equipment I have, its a device for setting up the blank and cutting it to make bevel gears the ID plate states the following:
Matterson Gear Generating Attachment
Model 12" Bevel
Brit. Pat Nº 143735
serial Nº MTOE 10074
Made under license by: ORMEROD ENGINEERS Ltd./Rochdale-England
It has been liying around my equipment warehouse for a lot of time, do not know how it came to sit there and no one has ever used, its in very good condition and seems an interesting piece of machinery that, if known how, could give fine work pieces out of its capabilities.
So if someone can give me a hand on how to set it up and operate it, I'll be thankfull
SACEM1
I'm going to answer this because I found the soilution, you can search in Yahoo or other browser the "Patents England" and you will be taken to the British Pattent records and there with the number you have full access to all the data involved, I got 15 pages and 6 drawings and solved the inquiry.
SACEM 1
