On-Line FEA Course 1
helmley
17
Does anyone one know, if there is an On-Line FEA course or a distant learning course on FEA ? Would appreciate any tips.
Hello, gentlemen!
I recommend you the course at
If you follow the links, you can get PDFs. However, for a specific code (NASTRAN, ANSYS) perhaps you should check on their sites or search on the net. I found interesting courses in NASTRAN/PATRAN on MSC's site, under Support link.
Regards.
Another option is to take a course a university through distance learning, Im betting you will learn a lot more. Of some of the ones I know are UT-Arlington, GaTech, U of I...Im sure there are more. Im pretty sure you can take them without applying for a degree.
The information provided were very helpful as some the sites mentioned did not show on the many search engines available.
Thanks a lot.[2thumbsup]
Helmley
