2D assembly sketch
Guest
I have been trying to follow the instructions in the help menu of Solidworks on drawing pulleys and a serpentine belt then extruding the pulleys in the 2D sketch assembly mode. I have not been successful. Can anyone help?
Sure, I can try and help!!
Somewhere and maybe someone else can remember where it was at, but there was a model already done that had some pulleys in it, with a serpentine belt already done.
You would have to in-context the models serpentine belt to the pulleys and when you change the dimension in the drawing (as long as it isn't a reference dimension) or change the thickness of the pulley model, the belt would snap to fit the pulley.
I'm I on the right track? If so contact me, and I'll help you iron this out.
Hope this helps, Scott Baugh, CSWP :)
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
