totti
Automotive
- Aug 1, 2001
- 8
Im not a civil eng but I have to estimate the wind load of a roof.So i dont have confidence about my estimation.
I used australia standard AS 1170.2
My problem is calculating the net basic wind pressure.The book says:
+the external pressure for windward section is -0.95kPa to 0.
+the external pressure for leeward section is -0.55kPa.
+the internal pressure is -0.7kPa to +0.75kPa
So,i think the net basic wind pressure for the leeward section is 1.25kPa(downward) to -0.75kPa (upward).
Is it correct,reasonable?
And do i need to concern about both case of loads (1.25kPa,-0.75kPa) in my design?
Thank you very mucn for yout help.
