OceanaRadio
Marine/Ocean
- Jun 2, 2004
- 5
After installation of multi-mode coax lightning arrestors, I have referenced several techincal papers that call for shield grounding at building entrance (done) and also at the bottom of the vertical drop and top of tower. My question relates to HF transmitting to a horizontal wire dipole antenna w/1:1 current balun. I have been warned by a colleague that microwave towers (where most grounding references come from) and HF do not behave alike WRT to standing waves on the coax feedline. Is there experience that would indicate that HF feedlines require more than one shield grounding to ensure the proper operation of TVSS/lightning arrestors? Would a second coax shield-ground at the bottom of the feedline's vertical drop be likely to cause an impedance "bump"?
TIA, Jack Painter
Virginia Beach, Va
TIA, Jack Painter
Virginia Beach, Va
