FrankTHutchens
Automotive
- Jun 21, 2004
- 7
A Viper performance shop is claiming that by going from 1/8" mild steel, to 1/4" aluminum for the 15"w x 30"long underbody plate that comes on most if not all 1992-2002 Vipers that
"Our pan will increase the stiffness and rigidity of your frame "
and
"The big picture for us is frame flex and rigidity when releasing the clutch @ 5-6K at the track."
I'm saying there's no way it's going to do much of anything. Typically aluminum plate has to be 1.5x as thick as the steel it replaces. So that means the 1/4" aluminum is only 1/16" thicker than a 3/16" aluminum plate of equal strength.
Also with the plate(s) only bolted front to back along the frame rails, and the 6 bolts on each side so near the edge of the plate, there just isn't any aprreciable anti-flex going on to begin with. Much less by adding a 1/16" thicker piece of aluminum.
The plate in question is mid-mounted on Vipers covering the trans and driveshaft area.
You can see a picture of the aluminum plate by copying this URL and entering it manually: (
I'd also contend that CNCing those giant Viper letters into the aluminum plate would just weaken the aluminum plate anyway.
Opinions please..
and
Opinions please..
