Designer_82
- Oct 17, 2020
- 62
Residential unit with heat pump, outdoor condenser.
The unit is whistling and all fingers seem to be pointing at undersized return duct.
The system design is 900 CFM and return duct is sized 14x12.
This equates to a sizing with velocity at 800fpm.
From all sources I could find, the indication is that this velocity rate is acceptable as the max.
Any thoughts?
https://postimg.cc/zbSLv391
Any thoughts?
