milkshakelake
- Jul 15, 2013
- 1,166
Do I need to consider hat truss with overstrength factor? Sketch below. This one is a vierendeel truss. I'm not sure what to make of it, if it creates soft story/vertical irregularity or not. I'm inclined to think that it doesn't, because the stiffness of the lateral system is a collective unit using the entire column on all stories.
