EngDM
- Aug 10, 2021
- 643
How particular are you guys with the proper capitalization of units on drawings? Personally I prefer that everything is shown with the correct letter case, especially when it comes to the units that are named after someone I.E. Newtons or Pascals, but often time I am reviewing drawings and everything is uppercase. So you get stuff in the general notes for a distance such as MM for millimeters, or KN/M.
I know it is unlikely that any errors are actually made from this, since the units are so standardized, but in a case where MPa is shown as mPa, it technically makes a massive difference.
