Detail View in drawing - Modifications 1
CAD2015
Computer
Jan 21, 2006
2,030
How could I make the detail view circle bigger (like in the attached picture, marked on red)?
How could I make the diameter of the circle bigger?
Thanks....
Right click the detail view (either in the graphics window or in the part navigator) and go to "boundary". This will open the view boundary dialog; make sure it is set to "break line/detail" (it should default to this) then pay attention to the prompt area - "select circle to modify it or select curves for different boundary". Select the circular boundary (either in the detail view or the parent view) and select a point to resize the view boundary.
It worked just fine.
Thanks a lot for your time/help!
[thumbsup2]
