Sketch Failure Message in NX
Jashe
Automotive
Jun 19, 2013
206
How do I either fix this or keep this from happening? I'm working with NX 1919.
Without knowing more but just from this message, I would guess that you somehow lost the sketch origin (either you suppressed something or maybe you modeled away something that caused the sketch origin point to be gone)
Yes, I used a point from the edge of a cylinder to create another cylinder and Extruded and Subtracted the Extrude from the body which included the edge that I used the center point. I tried using a point from a different edge. No luck.
