1 atm vacuum flange FEA constraints?
AHartman
Hi all,
This is my first foray onto these forums, having found them via a google search. I'm a mechanical engineer with access to Mechanica FEA in ProE. I've not done any B&PV designs before.
I have a mostly rectangular (rectangular but for a square removed from one corner) vacuum chamber flange which is 450 mm x 200 mm, and sealed with an o-ring whose groove is in the mating part. The chamber is evacuated and so the pressure delta is 1 atm in use.
My question is how does one model the deflection of such a flange to see if vacuum leaks will occur? My first blush attempt was to simply fix a strip of material on the bottom of the flange, following the contours of the footprint, then apply a uniform 1 atm load across the top surface.
This gave reasonable results, but it doesn't really tell me if the seal will fail, since I explicitly told the FEA system that my region of interest is fixed. How does one apply constraints to such a system? After the o-ring is compressed, there is metal-to-metal contact, but I can imagine that under enough central deformation, the corners of the flange could flex up sufficiently to cause a leak.
Can anyone offer some advice, or point me in the direction of some helpful reference material?
Thanks,
Adam Hartman
Repost in a FEA forum-particular to your software
I don't know Mechanica and I've never done something similar, anyway, I'd suggest to try modelling the o-ring (proper modulus of elasticity) putting contact elements between the o-ring and both the cover and the groove metal surfaces; for a first analysis "glue" type should be sufficient.
First load step: gasket seating.
Second load step: vacuum.
A comparison between the initial and final contact pressure should give some information about potential leak.
