1" hole drilled in bottom chords of wood truss 1
lubos1984
65
Greetings to all,
An architect called me with an issue at one of the projects he's managing. Apparently the electrician drilled a 1" dia hole through the bottom chord of the trusses. The bottom chord is a 2x4 (1.5" x 3.5"). The truss manufacturer does not want to evaluate this, as their instructions are clear that no holes are allowed in the trusses.
I checked the truss calculations, and the bottom chords are loaded at about 0.35-0.55 MAX CSI, mostly at around the 0.35 mark. The architect told me he sees this often, but from my experience, I haven't come across something like this?
With less then 2" edge cover, I am concerned about splintering at these locations.
Wondered if you guys came across something like this and how you dealt with it ? The electrician did this through most of the truss bottom chords!
Thank you as usual for all your help!
XR250 said:
To add to Koots detail, you could install another 2x4 web near the hole that intersects near a top chord panel point.
OK, this was Dumb. I believe KootK was talking about global deflection of the truss after the chord fractures. This would only work for localized chord deflection.
