1045 vs. 4340
brane23
50
I have a client asking to use 1045 steel in place of our specified 4340 steel. We require 320-360 BHN and our client assures us he can achieve 280-320 BHN with 1045. From what I've read, this seems unlikely. What is a good source for this type of materials information? Thanks!
You need to supply more information before any of us here can give you a good answer. What is the configuration and section size of the component in question? What is the application?
24" P.D.~18T~3/4" D.P. ~5" 4.188 Circ. Pitch
What is the maximum section size (thickness) for this component? I doubt that 1045 has the hardenability necessary for this, and certainly will reduced toughness and fatigue strength. I would not make the change unless the stresses are very low.
1045 is completely inadequate for through hardening in this type of section size. Only steels with exceptional hardenability can sufficiently quench to near 100% martensite in that type of section size. Your "client" (do you mean vendor/supplier??) apparently does not know what they are doing. The center of a 5" section of 1045 will have a hardness of ~ 225 HB and a microstructure of pure ferrite + pearlite after any type of quench and temper treatment.
You can achieve your required hardness range from 1045 but it would require a water quench or possibly a polymer quench.
I would not recommend a water/polymer quench for a gear.
My sources are from information supplied by the Old Line Steel Companies for all the products they made. I would check with your supplier to see if he has tempering curves for the products he sells.
There are several books on heat treatment of steels that have tempering curves. I can recall any titles but you could search the ASM website for information.
It is possible to harden the teeth of the 1045 gear by induction hardening. But as this is a major process and configuration change, the viability would have to be established by testing. Not exactly a "drop in replacement" for a 4340 gear.
For 1045 to have sufficient induction heat treat response, it is best that the chemistry is a high side composition, i.e. C=/.46-.49, Mn=.80-.90, with some residual Ni-Cr-Mo up to .20 combined. The chemistry still may not help the hardness much if you need 280HB in the core.
I've seen a lot of gears and pinions in 1045 in that size range. All depends on the service - ie, is the normal failure mode wear or does it fail by spitting teeth?
If it is straight wear, then 1045 and 4340 (after suitable heat treatment) are going to behave in a similar fashion. If it is tooth fracture, then 4340 will be the far superior grade.
That said, I say that if it is a small run, just go for the 4340 and be done with it.
LewTam Inc.
Petrophysicist, Leading Hand, Natural Horseman, Prickle Farmer, Crack Shot, Venerable Yogi.
