we faced a problem in power plant consisted of 4 diesel generators 400 v synchronise togather and every generator connected to 400v/11kv delta/wye Transformer the synchronisation in low voltage side (400v) when we turn on the first generator it's transformer rise up the voltage to 11kv and this voltage delivered to all transformers in the high voltage side (11kv) but in each low voltage sides of each transformer there's only two phases live and the other one have 0 voltage ( we tested by voltmeter ) we tried by starting from other generator but it's the same problem. all the for transformers act like that (when we feed it from low voltage side it work perfectly but when we feed it from high voltage side there's missing phase in the other side (400)!! ... could u help me plzzz ???
