I`m looking for a connection detail that can be used for connecting a roof access ladder to 2x6 stud wall with brick veneer.
I would like to use L3x3x3/8 angle brackets spaced at 6ft apart with Ø1/2 through bolts.
My main concern is a wood blocking detail to provide adequate support for the anchorage.
Can you guys suggest a solution that you have used before in similar case?
Any suggestion would be greatly appreciated.
