PostFrameSE
- Sep 5, 2007
- 174
When calculating the tributary area of a girt for the determination of the appropriate external pressure coefficient, I'm wondering do I use the entire length of a multi-span girt or do I look at the tributary length as though it was from support to support? In other words, if I had 10' o.c. columns with a 20' girt spaced at 2' o.c., would my trib area be?:
1) 20sf - 10' x 2'
2) 40sf - 20' x 2'
3) 33.3sf - 10' x 10'/3
4) 133.3sf - 20' x 20'/3
Number 3 and 4 of course are using the provision of 1/3 the span length.
Also, for purlins spaced 24" o.c. on a roof structure with corrugated steel sheathing attached to each one, is it possible to take the tributary width as something greater than the spacing of the girts due to the load-distributing steel sheeting?
Thank you!!
1) 20sf - 10' x 2'
2) 40sf - 20' x 2'
Thank you!!
