sambullion
- Jul 5, 2008
- 5
Ok guys the equipment is a 155 ton split chiller.
as described 3 phase 208 voltage 1.5 H.P. motor ,
some of the fans will change rotation or rather run backwards at start up and then the next startup will run in the proper rotation,
Notes current checks are ok so far. motor ohms out ok .
voltsge checks good never had this type of problem, am i lossing my mind are is it so simple i cant see the forest for the trees.
Thanks Sambullion
Thanks Sambullion
