Need to use a 3-inch force main, almost 3 miles long. SDR 21 comes in 3-inch but obviously not common. SCH 80 is readily available in 3-inch but not sure if the belled end SCH80 is readily available.
I have two questions:
1) Do you concur with the SDR21?
2) What type of fittings would be used?
Thanks in advance, I'm not overly familiar with the small diameter stuff.
JT
JT
