3 phase motor monitoring
xJAyx
100
Can a single phase current monitor be used to determine if a 3 phase motor is running? I don't need an analog indication, only running or not running. Under normal conditions, I am confident that the single phase current switch will be fine, but my concern comes if I blow a fuse on one phase. It's an old panel so the motor is fused individually on each leg.
What will happen if I blow one phase? Will the other phases blow from the load change?
Just copy and paste the url in the address bar and it will work. I tried it and it is OK I must not have hi-lighted all of it when it was copied.
Tom
None of us is as smart as all of us.
Tom,
It's a limitation of how the site processes HTML. When it encounters a $ symbol it truncates the address at that point. I'm sure folks can figure it out from what you posted.
image.php
Thanks Scotty, I thought that I had goofed.
Tom
