316 Stainless - Shear strength - Sloppy punch press 1
Shockdesigner331
69
Hey everyone, got a question regarding the shear strength of 316 Stainless Steel.
I have a design that utilizes a punch press of sorts. Basically it is a load limiting device that breaks at a certain load.
The loads are quite high and the parts are huge so the shearing "plates" have a radial clearance of .06 inches. FEA shows that bending and shear is going to occur.
I know that 316 work hardens when drawn and that increases the strength, this is sort of a drawing operation until it breaks. I think.
I've heard that all stainless steels have a higher than expected shear strength when punch presses are used.
I need to figure out what is my governing failure mode, to do that I would need to know the ultimate shear strength, and the ultimate tensile strength which corresponds to the amount of cold work done. (I think)
Any help would be appreciated.
300 stainless alloys work harden a lot.
In my experience the fore required to shear or punch stainless is about 50% more than for carbon steel of the same gage and strength.
This is discussed at length in some of the metal forming handbooks.
Plymouth Tube
