iangineer
- Nov 5, 2020
- 68
All,
I have a tower made of 316L SS that has some corrosion due to the acid service. The minimum wall thickness due to internal design pressure + hydrostatic head is 0.429". Some areas around the bottom of the tower show thicknesses close to 0.350". An FFS evaluation passes at Level 2 for 5 years.
120" ID
ASME VIII-1
My question:
Can weld metal buildup with Hastelloy be used to bring the wall thickness back up to nominal per code?
My thoughts:
PCC-2, Article 211 specifically says that weld metal buildup can be used for damaged base metal in carbon steel or low alloy steel applications. I believe 316L is not considered low alloy. Weld overlay refers to application of corrosion resistant weld material. My counterpart believes that overlaying the 316L with Hastelloy to bring the wall thickness up to nominal would satisfy the code requirements of bring the pressure boundary back up to proper thickness while upgrading the material with corrosion resistance.
I just wanted to find a code that specifically states that this is a proper repair. In my experience with new equipment design, a weld overlay does not affect the pressure boundary base metal.
Any guidance would be appreciated.
Thank you.
120" ID
ASME VIII-1
My question:
My thoughts:
Thank you.
