400 Hz power supply for Embraer aircraft
400Hz
New member
Oct 8, 2010
We have installed a new 400 Hz power supply (static converters from Axa Power).
We receive Embraer, Bombardier, Airbus A320 and Boeing 737.
All aircraft connecting to this power supply have no problem, except the Embraer 170 and 190.
Did anybody have a similar problem and may know the reason of this problem?
Please describe the problem. I may have seen "similar" problems if I knew what the problem is.
Are you referring to problems with the GPU?
Is this during the engine-starting?
Thanks for your message.
Our problem is not during the engine starting, but when the aircraft arrives to the terminal: we connect the plug to the aircraft while the APU is running.
There is a light marked "available" next to the aircraft socket. Instead of lighting, it flashes, and the pilot does not get the information in the cockpit that external 400 Hz power supply is available.
This problem appears only between Axa Power 2200 solid state converters and Embraer 170s and 190s.
