Clue144
Automotive
- Jan 17, 2009
- 1
ok this is a quik image i have made
those thick black lines are round tubes to spin ... my 6 axle
and i whant to spin them one at the time with 2 dc motor if its possible.
if motor 1 spins right and motor 2 spins left then the first axle will rotate.
if motor 1 spins left and motor 2 spins right then the second axle will rotate.
if motor 1 is stoped and motor 2 spins right then the third axle will rotate.
if motor 1 is stoped and motor 2 spins left then the fourth axle will rotate.
if motor 1 spins left and motor 2 is stoped then the fifth axle will rotate.
if motor 1 spins right and motor 2 is stoped then the sixth axle will rotate.
Ok i hope someone understand this, this would work if i know how to build it, I have a couple of gears but its seems impossible.
Can anyone help me, show me or explain how exactly i can do or give me another teory to make this ?
