DONKUMPUNEN
I work as QA SPECIALIST on US NAVY destroyers. The firemain and sea water piping was recently changed
from 90-10 copper nickel to 70-30 copper nickel but some of the fiittings are still 90-10 cu-ni as per the
drawings.The pipefitters in this shipyard have at different times installed valves backwards,strainers backwards,
and installed wrong material piping.
I think that by picking and choosing where you are going to use 90-10 fittings or 70-30 fittings there will be confusion and mistakes made.Is a 70-30 fitting that much more expensive than 90-10 fitting?
Any opinions out there on this? DON KUMPUNEN
