A completely new piston engine architecture
3% power loss in the gears and a decade of work for NVH engineers. What's not to like?
Amazingly it still suffers from second order vibration due to the cranks.
Before you do that, do an FEA on the camdisc.
Compact size is the only advantage that I can see.
That cam disc looks like a nightmare though
Would not be hard to make it workable - reduce the diameter of the cam disc or change it from axial to radial lobes.
A gearset between the crank and the flywheel? Aaaargh.
Maybe a barrel cam.
Maybe sleeve valves or slide valves.
It might be ok ish as a compressor with spring disk valves.
Anyway, backlash in the gears will be a killer.
Other than torpedoes have any of the swash plate engines found a niche?
Well, that's up to you. Probably a wise decision, it'd be putting lipstick on a dead pig.
Is there a purpose to this thread? A question? Discussion of a new engine that's actually being developed by a competent engineering team?
Or is it simply an attention-seeker sharing a rough doodling, like the millions of AI-generated, amateur vehicle "concept drawings" littering social media?
Thermodynamically, it's exactly the same as an engine of conventional architecture. So, no advantages. The output shaft operates at half crankshaft speed - so, double torque and half speed compared to a conventional engine operating at the same piston cycling rate. Meh; there's easier ways to do that. It separates a single crankshaft into a bunch of separate ones. The valve actuation cam will have a very high surface speed and the rocker arms are pivoting off-axis from the direction that the cam is rotating, which makes the contact interface between them interesting.
Meh.
I'd put money on this being AI generated. AI isn't actually intelligent so it doesn't know how stupid this is.
